OK I just received a 47 amp 51 surge power supply because I always felt my Mega Watt S-400-12 power supply might be over taxed and not allowing my amp "RM ITALY KL-503" to work to it's fullest, but the Mega-Watt supply always ran cool and has never shut down. Well after checking the meter with the new power supply DK. and audio peaks I now know by comparison that the old Mega Watt is not only powerful enough but has absolute silence when in operation. The new one gave me 9 db's of hash like others I have tried. Now when I brought out the multi meter to check my voltage I noticed on my watt meter the wattage out put for example 12 watts flat vs.13.75 can mean a whopping 100 watt difference 13.75 is the higher reading of course. Now I know a little about automobile's and if you got a 12 volt reading you would soon have a dead battery and speaking on dead batteries say you have a good battery and alternator and left the lights on after getting a jump start and checking your voltage it would be common to get readings as in the high 14's. I also run a separate power supply for my 148, meter lights,etc. It appears to be a Trip Lite very large unit big heat sinks heavy but I do not know the output "no I.D. anywhere" but is also silent in operation. Now back to the question if I had this amp in my mobile which puts out more than 12 volts most of us would not worry so is the mobile base running higher volts and getting dramatically more watts is this somehow a false reading and would the amp soon go kaput I am running the same amps in both my trucks for nearly two years they run cool and still work. I really want the nearly 100 watt increase by running the power supply voltage at 13.75 but get the feeling I am going to get the air taken out of my balloon Hey thanks for reading guys!
