Higher voltage = higher wattage output?
Nice! I guess asking a question about one hundred watts is ridiculous on this forum. I wonder how many people out there do not post any questions because of this ridicule they will receive. And no this is not a isolated incident. It's one thing to answer a smart ass question with a smart ass answer but this attitude of "you are not worthy peasant" is prevalent here or it's the same bunch talking all the time.
CHILL DUDE!!! DANG!!!:bored::love:
Guys on CH 6 and keydowns volt their boxes, but hey, that can do this because well, they can!!!! I value my gear so i run it at 13.8 volts.....
The KL models should never be volted. As a matter of fact and amp that is made should be not be volted. Especially if it is biased any way besides class C. It will pop in seconds. There are a few exceptions to the rule. The Davemade, fatboy and Xforce line of amps can be volted ( not the midnight specials though). And if these are volted, you better know what you are doing. SWR/ reflect needs to be nill. The higher the voltage, the less drive is required to excite them. Still at the cost of transistors nowadays, why even take the chance? If you want more watts, get a bigger box that you can loaf. Sure I have volted pills even over 20 volts. But to do so is at my own risk. I have popped a few in my day. Enough to fill a jar. As I stated and I think others stated. Run it as recommended. Otherwise up grade to a box at least twice the size. The little extra you get volting is not worth it. If amp blows. Can you afford to replace pills? Or buy a new amp. Just my 2 cents. I'm done
I thought P=IV, or P=I squared R
It does. P=power I= current and V=voltage but the proper symbol is E for electro-motive force which is voltage therefore P=V (or E) times I times the efficiency of the amp as nothing is 100% efficient. You can rearrange the formula to determine any one unknown from any two other known quantities.
The only real reason to volt an amp is in a keydown competition, riding around while volted is just doggone expensive because you will blow at least one 2879 a day. The 20 volt guys obviously make way more money than me.
As I said for everyday use, run it on a stock system. It will last a lot longer. Most guys don't realize that when you do volt a box, you need to decrease the input drive. Guys that are doing competitions, yeah they volt the hell out of them and they do it for 10 seconds. Go or blow is the phrase used. There is a reason they call it go or blow. Every key is a chance.
    Greg T has left the room.
