Non-radio wiring question for those who know 110v electrical code - really appreciate any help to know if I did this whole thing to code or the right way for that matter.
So I consider myself pretty savvy when installing radios and all things DC, but when it comes to home wiring I’m a little more careful so I’d like to make sure I’m during everything properly and to code.
I bought a security camera that had all the features I wanted (ebay – Chinese PTZ model) and it came with a AC-DC converter 12V 4a (similar to a laptop style one). Non-UL approved of course. Problem is that my camera is being installed outdoors permanently – there is a socket (GFI) right below it but I need a 12V converter I can plug in outdoors that is weatherproof.
This will be a long term outdoor install (5 years+)
I bought this UL approved IP67 converter - Amazon product ASIN B00NPAKTVM
It has the plug that will plug into the security camera DC plug but it didn’t come with a 3 prong plug to plug into the outdoor socket so I need to wire one.
I bought a 8ft 16 gauge replacement style wire from lowes but my question is regarding safe wiring for code in this outdoor install. I wanted to wire the replacement cord directly to the converter but it’s sealed up very well and I don’t want to pull out their cord and put mine in and then have it not be as waterproof where the wire comes out of the case.
# 1 – I bought a plastic marine junction box (like this http://ace.imageg.net/graphics/product_images/pACE3-17464436enh-z8.jpg ) that has the black seal and drilled holes on either side for the power wires to come in – the holes are barely big enough for the wire to squeeze through so the junction box is basically sealed.
# 2 – I bought specialty waterproof twist wire connectors - https://www.lowes.com/pd/DryConn-25-Pack-Plastic-and-Metal-Standard-Wire-Connectors/3726292 and hooked up the green/white/black accordingly and put the wire caps on. Then I used small zip ties and zip tied each set of wires together (to prevent any risk of them pulling apart and coming out of the wire cap).
# 3 – I put a larger zip tie around the two black input power cords to prevent strain on either side from possibly pulling the individual smaller wires apart.
# 4 – Mounting – The junction box will be directly screwed to the wood trim on the outside of the house and the power cord will run down to the outdoor outlet (which has the locking outdoor cover with the small divot for the cable to run into).
# 5 – The AC/DC converter mounting – I was going to try to find a junction box to something for it but I couldn’t find anything to fit it (everything was too large or too small), and I was worried that anything too small/tight might make it get too hot in the summertime if there isn’t any space for air flow. It’s IP67 rated but it’s Chinese and I’m not sure about mounting it directly to the wood trim – as a safety precaution I’m thinking I’ll use spacers with the screws so it will sit about 1” away from the wood so if it overheats, sparks, burns up, etc, it won’t be right on the wood.
#6 – The connection of the security camera and converter wires I’m going to wrap in some electrical tape and then use heat shrink tubing over the top.
Any input or other suggestions?
