Unfortunately we've had thunderstorms all day and their not supposed to move out until 10 pm. Hopefully tomorrow I can get this thing on a more permanent pole and see how she works.
I may get some more ss 102 whips, my initial plan was to use only 102s . I could also use some better coaxle.Wally, I use to make a Starduster kind of vertical GP antenna out of 4 or 5, 102" SS whips, with an A99 hub, using a mobile mirror mount. See images below.
With these full-length 1/4 wave whips, my SWR Bandwidth and Match were almost perfect...over a nice wide range <2:00:1.
Up high the performance was also great compared to other GP's used if the tips of the antennas were anywhere close to the same tip height.
I would also think the shorter mobile antennas, you used for the GP, would also work similar. If you can find some extra SS whips, beg, or borrow, and try them.
Also make sure your feed line is not radiating, acting like part of your antenna.
Eddie
Yes, it's a lot of funWell done Wally. Looks good. Isn't that so much more enjoyable than just BUYING AN ANTENNA??
