Sorry. I used 3/4" with 1/2" tubing. Use 1" PVC and use tape for shim. My bad...OK a question 3/4 pvc id is smaller than 3/4 emt or 3/4 copper pipe OD how did you get that to work? unless I missed something
lmao I was going to do that but I wanted to make sure i got the pole they had no shake spears so i grabbed the black widow same thing i hope inside tooSorry. I used 3/4" with 1/2" tubing. Use 1" PVC and use tape for shim. My bad...
So just bending the stinger wire over will equal to cutting itI discontinued putting the upper wire inside as it was a pain adjusting for SWR. I just folded the wire until it got right. I never bother with shortening the excess pole. I use tape or heat shrink to prevent the pole from retracting.
I cut off the plastic cap and threads from the big end of the pole. It would then go into the PVC nipple.
As for the bottom tube, I'd use tubing cutters cutting from the bottom, use tin snips to remove the trimmed off pieces.
Yes.So just bending the stinger wire over will equal to cutting it
wow never knew BTW I really appreciate your helpYes.
Ok then I snip the end off the pole then match it and cap itfolding is better so it can be unfolded if necessary.
Im about 8 mile from 23 east bound How ever I can try with my mobile also it has some help Ill give ya a call outGotter getter dun!
I’m on IH75 tonight just north of you (10 Air Miles to town center) and will be using M-23 several times over the next few days (short round-trips from Flint, MI into Ohio & Indiana thru 08/13).
First trip south will be due west about 0730 tomorrow. Then going back north at around 1400.
PM me if you’d like.
Might be some fun if this ol’ trucker could hear you on the way past. Trucks got decent ears, but TX still no bueno much more than about seven miles (AM-19). SSB might be better.
Looks like M-59 where it crosses M-23 is the shortest line. Can’t read air miles distance from Milford @ Livingston out to there.
well finish it and 6.0 trim till the stinger was 95 inches I GIVE UP either coax is bad or?? Im outa coax so will have to drive an hour to get that nobody withing 60 sells coax unbelievable pole probably wasted now do to trim and no patience..folding is better so it can be unfolded if necessary.
