I know what it's like CK I was about 9 when Aus changed. Best idea is just use metric and stop trying to convert it all the time, thats when most confuse themselves.![]()
Tell that to Myanmar (Burma), Liberia, and the USA.
Use metric and not that silly antiquated feet and inches. 11m x .64 will get you close but you have to allow for velocity factor of element used.
That's what I've been running all along.... Maybe we should call it the 12 yard band to accommodate.
not dave ..its mikeHows it going Dave. Maybe we should call it the 12 yard band to accommodate.
Sorry about that Mike, hows things in NZ
I use 11778 divided by frequency in mhz ( = wavelength in inches x .9979, VF of aluminum in air) and I believe 'end effect' only comes into play on 1/4 waves, but it's been decades since I researched it and could be mistaken, though the Penetrator calcs out perfectly w/o using it. I also deduct the average circumference from the calc'd length, a .64 for 27.185 ends up being 22" 11".tank you to all that replied. im not very good in math and metric is greek to me..lol. with winter coming here in pa im starting to think bout inside projects/hobbys. im not sure
if ill make a antenna ..especially a 5/8. maybe a 1/4 wave seems it dont need a matching system.. the fourmla i mentioned i found on utube by a ham op. has several for many different designs
