The quote tag got ruined in the post, It's fixed now.HUH ???????
was anything I mentioned untrue (I might not have a complete understanding)?
Have you tried to transmit 30khz wide? Its not quite as easy as you may think.
Whats wrong with 10khz wide? Whats the limit on how wide you can transmit? As long as your not interfering who cares?
There has got to be a simple software solution that can reveal how "wide" an element In my microphone I have, can anyone offer a suggestion?
However the mic element response width isn't what controls how wide your transmission is. Filtering on the radio and spurious harmonics caused by overdriving the radio is.
That's where the processing comes in to severely limit what gets directly injected into the radio (using software "filters"/e.q. ) on my test setup, later I plan to make a buffer/filter circuit.
I said as long as your not interfering who cares! That was a more aimed to the ham bands. The CBer was obviously interfering. So answer my question even on the CB band how is it that my signal that I recorded is considered interfering or bleeding over?You bleed over the adjacent channels. The limits are defined in Part 95 certification. Who cares? The people who you're bleeding over on the adjacent channels and the FCC. The FCC recommended fining a CBer in New York $22,000 for operating a 150W linear and interfering with other CBers. The base fine for both of those totals $17,000 with an additional $5000 being added because he continued to ignore them.
What is the problem is the levels that are injected, not the bandwidth.
Yes it is my radio!To me direct inject seems like something that is real easy to do but hard to do right, if you're going to bypass all the limiters in the radios mic amps the onus is on you to monitor/limit everything yourself. Not everyone does this but you can't blame that on those that do keep on top of things.
If I was going to get that crazy with the audio I would consider an oscilloscope and a SDR receiver with a panadapter type display requirements for monitoring purposes.
PS: Is that your radio in that clip you posted JoeDirt? if so that is one nice setup you have there.
It is extremely easy. You just crank up mic gain to the point that the ability of the ALC circuit to limit it to a reasonable level is exceeded. You can transmit 30kHz wide on any amateur radio by whacking the mic gain right up, turning the processor on and whacking that up too. You don't even need to crank either of them up to full.
Joe dirt is talking about a transmitter capable of passing 30khz of audio bandwidth and a someone that's been licensed since 2009 with a arsenal of plug and play appliances tells him this....
Someone who did a degree in electronics engineering, has been an electronics engineer since 1986 and who has a wall of first place certificates for CQ-WW, CQ-WPX, IARU HF and ARRL International DX contests. What are your qualifications?
You seem to confuse having a license with having competency whilst discussing technical issues on a forum about an unlicensed service.
