How much is this worth?
As far as heavy loads go you would have to add axles to gain more capacity. The spread axle on the trailer is an exception....You can go up to 20 ton on a trailer with a spread where as one without you can only legally axle 17 ton
WOW,
We "hi-jacked" Moles thread :lol: :lol:
Try running a "Sand Box" in Florida....you will learn real quick what "Bridge Formula" is...73280 on 4 axles.....single axle tractor with a "Florida Spec" dump.. :wink: :roll: :roll: 22' or 24' box on a 28' or 30' frame.....haul 25 tons legal all day long.....One of the few states that maxs at 80000 regardless of # of axles on the ground :twisted: :P .. I'm legal for 65000 on 10 wheels (3 axles) :wink: 8) with only a 15' body....up here in New England
Hamer or Mr.Peddler,if you need to move this to the "Truck Zone" do it at your own risk.........only" CDL ,Export Radio hoarding Big Riggers" allowed to move such .............. "precious cargo" :wink: 8)
And "Boss" sorry to "hijack" your thread :D :wink:
Snoope back hiding in the snow.........
Yea my apologies too fellas.....Sorry for the hi-jack
Id hang on to that 148.....They are a rare find these days in "unhacked" form. If you do decide to sell it, from your description, id say $100 to $125
  • @ Geoexplorer69:
  • @ Geoexplorer69:
