Hello All. The trouble i am having with my President HR-2510 is ,
when it is left off for a couple of days , it will not turn on rite ( let me explain) . back in the early summer when it was very humide up here in Ontario, i had my radio at home ,in the basement cleaning up my mic , antenna and coax , it was nice and cool in the basement , when i went to work on monday it was very humide out , but everything in the trunk of car , got to work opened trunk
and everything was damp , boy was i Pisst. i got it in my truck and wiped it off , went to turn it on and all that worked was the display lite. there was no display , a little bite of white noise that was it , nothing else worked ,opened up case and the circuit board was damp to , i wiped off what i could from the circuit board .and let it sit in the front window of my truck for a while , to let the sun dry it out , about an hour later i turned it on and eveything work fine ,, now it is about about 5 months later and it is doing the same thing just more often ,after sitting for a couple of day's you turn it on and just the display lite comes on, you have to turn the radio off and on about 10 times , and then the display will come on and the radio is fine for the rest of the nite, turn it on the next day , it turns rite on no problem, it seems like something gets stuck after sitting a couple of days, My question is ? , is there a mechanical relay in the circuit that could be sticking, if not, any ideas what it might be ? (Sorry for the big story , i just wanted to explain it from the start.)
Thanks for listening , i hope someone can help.
