Hy-Gain SPT-500 Super Penetrator
They all very good...so i read, i have not used them ...it depends what you want/need which is best for you the i max has a very very wide bandwidth and i believe it handels a good bit of power, heard of folk putting more than 1kw.. The SPT500 will handle the most power the gain master the least..
imax very easy to setup and get in the air
which gets out the best in order Gainmaster, SPT500, with the Imax a close 3ed...but then in another location it maybe the other way round
I have two of the original P500's! Great antennas. One is new in the box. Im pretty tall, so one will be next to me in my casket!
Buy one you'll like it!
I've had all three antennas and the Gain-Master has the best signal in the distance. This 5/8 wave has a definite advantage over all other 5/8 waves and is why there is a patent on it. The improvement is not some extreme amount but it is noticeable. Anytime I can get a gain in signal while doing away 36 feet of radials is a nice plus. The Imax would be my last choice.
