Penedusters, Startraters and the Desert...
Hey what ever happened to the desert test? Was that the one no one was able to make?
And I know this is an old posting, but 1976 is even older and that's when I was a Sophomore trying to get the best performance I could from an antenna.
I was quite competitive back then, football, wrestling, bike racing, water polo, ...Cb radio.
I really wanted to feed my big 16 year old ego and have the king-sh!t station, so I bought and tested every ground plane antenna available, plus the Big Stick, Astroplane, Starduster and Magnum44(POS!) I decided I would keep the best performer and sell the rest.
For testing, I used several locals, one in Woodland, Ca who had a Moonraker and was about 30 miles away, and another in the mountains about 45 miles away above Nevada City, along with one other near Angel's Camp which was about 75 miles from me, all of whom I picked because, like me, they used Johnson Messenger 223 radios which have both an AGC circuit and a meter like a piece of test equipment, and the needle on that radio is like 2-hair-widths, bright dayglo orange and easy to read because of the bright white meter background.
I still own 7 of those rigs.
My test results showed the Sigma5/8 to be 1/2 needle width down from the Penetrator on TX, and 1/2 needle up on RX.
I attribute the slightly extra RX on the Sigma to the lack of top-hat radials, thus allowing it to be about 10" taller, providing slightly more vertical capture area. I believe the elevated radials provided the slightly higher TX on the P500.
- Talk about indecisive, for two months I couldn't make up my mind which I wanted to keep. Remember, I was a Sophomore in High School and 2 months back then was like two years is now to my 50 year old ass!
I ended up keeping the Penetrator (which I still have, cleaned and re-installed yesterday!) because I like the radial build quality better. It always seemed like they (Avanti) took the cheap way out with those little 3' pieces of solid rod at the end of the radials for birds to bend.
I also cracked the aluminum hub which holds the radials, even though I THOUGHT I was being careful not to over-tighten. (...Wrestling, football?)
I did, however, prefer (and almost keep) the Sigma radiator because it seemed like it was heavier and more stout than the lighter Penetrator radiator, but I couldn't successfully interchange them due to the different lengths & sizes, the Penetrator top hat piece not fitting, etc...
So, years ago I read (where it was I do not remember) that Hygain designed the elevated radials to split the current in order to attain a lower take-off angle of radiation, and add horizontal components. I believe this and have noticed better horizontal receive, on stations running horizontal, with the P500 than with any other 5/8 I've played with over the decades, except the Taylor Grandslammer GLR-4 ( I sure wish I would've kept that one, talk about rare!) which also had elevated radials.
OK, so, do I get the long post of the year award? Sorry about the 'book'!
