ever since i got it ive had a problem where as if the radio was cold the power was way low,once you left it on a while it would pick up and do some decent wattage.i took it to the local radio guy and he managed to get the power to be higher when it was cold but it would still increase when it warmed up.he suggested to get a can of component cooler and start spraying different areas when it warmed up to see where it changed(he didnt have any cooler at the time)I just got some and ran the test(gotta love the deadkey button on those radios) when i got near vr107 the wattage went crazy and I was able to determine the pot is bad.if you even bump it the wattage will change.I found the value and ordered some from fleabay,well find out in a couple of weeks if it fixes the problem.
