I want a 100 amp power supply
Megwatt they are nice I like mine and have had it 2 years now.
For Texas Star DX500 this would be perfect and you wouldnt be pounding the hell out of it to where you burn it up
Megawatt
S-1200-12
80 amps continuous 100 amp momentary peak at 12 volts
Adjustable voltage 9.5-14 VDC Output 960 Watt Continuous
Input 120/240 VAC
$240.00
I recently purchased 2 server psu's. Cosel PBA600f 15 rated at 600 watts at 15 volts They don't even get warm at 40 amps 14 volts.They have built in load sharing control so you can hook them up in parallel or change the jumper and hook them up in series. From memory you can parallel up to five units. Like most switch mode supplies there is some noise( about s1 ) I only use it now and again as I find the fan noise a problem with long term receiving . Watch the rating on those 12 volt supplies.1200 at 12 volts is 100 amps 1200 at 13.8 is only 87 amps. 100 amp linear supply would be the go if .
.A you could afford it.
.B you can find one
.C if you have room for one. it would be huge.
    Greg T has left the room.
  • @ Galanary:
