IC-7000 ext display
I use a little 7" Coby portable TV with my 7000. It's not an HD tv and doesn't need to be for the 7000. Anything larger than 7" or 8" and the on-screen text will start to look blocky. (tired it with a larger computer monitor that I hacked up a cable for. Looked BAD)
The output from the 7000 is not that high at all. So, you should be fine with what you are getting. It certainly does make it easier to see settings when you change them too!
trucker
trucker
Yea I tried it on my 40" HDTV at home and each number was in blocks about 1x1 " blocks. LoL
Sent from Outerspace, on the DarkSide of X.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
