Click here to find out how to win free radios from Retevis!
I have an ICOM IC910 and the display is fine if viewed from above. When face on, the display is faded and unreadable. When viewed from below, the display disappears. A ham friend has a IC910 with the same problem.
Any suggestions?
There is a conductive rubber between display and PCB.
To fix that you need to disassembly front panel and clean that rubber strip, pcb contacts and display edge where that gum goes.
Google translate that: http://arifidenza.it/Forum/topic.asp?ARCHIVE=true&TOPIC_ID=365269
Mike
