ICOM IC-7000 External Fan
Mudfoot
Elmer
I Support WorldwideDX.com!
Jun 17, 2009
11,059
6,435
698
63
Southeast Ohio
Is it really necessary?
Anyway, I was wondering how many operators have owned/tried the external muffin fans or some other method of cooling on their 7000's.
I am suprised that they run so hot, even if only receiving. I suspect the engineers that designed the rig know what they are doing.
I just got my 7000 from HRO and it came with a 2 year warranty during a current promotion, so I am not to worried yet.
Just wondering if it's worth the time and effort to add a fan.
AC8EO
If your radio is getting that hot then adding a fan would be (imo) cheap insurance. It seems like it's hit and miss with the running hot issue. I've read of others having a problem, but the temp gauge on my 7000 has never run in the red. I know a couple locals that also run the 7000 and they have never had a problem either. If you do put a fan on it you may want to consider a brushless type and a couple wraps of the power leads around a ferrite bead to eliminate the possibilty of fan noise in your receive.
Same here, my 7000 never gets into the red even when I am into a long
QSO. It does feel quite hot, but, it does have a large heatsink. It shouldn't
have problems.
If it makes you feel better, direct a small fan on it. Just be sure it's not
blowing against the internal fan when it kicks on. (mine rarely comes on)
Otherwise a very great radio.
james
aka:trucker
some 7k's run hot,..... some don't:confused:
excess heat WILL destroy electronic parts.
there is a well documented fan mod for the 7K
  • @ Geoexplorer69:
  • @ Geoexplorer69:
