Imax 2000 and added coil?
2RT307
Sr. Member
Nov 22, 2011
2,363
824
223
Texas
Hi guys, just pondering this for use as a portable setup. I have an Imax 2000 that is just sitting. Have wondered if you could add a large coil inline (Wolf River or similar) with a tuner and do multiband operation , say to 40 meters? Easy enough to break down and toss in my pickup bed, and also carry to a camping site and set up a station by driving a short pole into the ground and mounting it up.
I don't find anything on the internet other than extended telescopic antennas and the like. Any ideas? HomerBB?
73,
Brett
The Imax will already work well with a tuner down to 15 meters. If you jury-rig it to go any lower it's probably not going to be efficient at all and you're just forcing a match that the radio will like. If you want 40M portable .... get an antenna made for the band.
73,
Brett
Hi, Brett.
I love Wolf River coils. Have worked many countries on 20 and 40 meters using their mini coil, a 102” whip and a single wire radial 16.5’ in length. My guess is an Imax 2000 will get you 80 meters as well. An no need for a tuner. Simply tune using the coil’s sliding clip. Unless you don’t want to do so each tine you change bands. Then a tuner might come in handy. ;)
Reactions: 2RT307
I already have an end fed random wire to do that. It is difficult to get in the air sometimes. Adding a coil is common enough, except typically with a 102" whip, or one of those MFJ telescopic things (which are pretty fragile). I may have to just try it and see.
73,
Brett
Reactions: Riverman
Hi, Brett.
I love Wolf River coils. Have worked many countries on 20 and 40 meters using their mini coil, a 102” whip and a single wire radial 16.5’ in length. My guess is an Imax 2000 will get you 80 meters as well. An no need for a tuner. Simply tune using the coil’s sliding clip. Unless you don’t want to do so each tine you change bands. Then a tuner might come in handy. ;) heard good things about them, too.
Hi, Brett.
Hey Riverman, good to see you here! Glad the Wolf River has been working well for you.
My thought for the Imax was it is a lot more wire in the air than a 102" whip, which is a good thing. Seems easy enough to mount it in the ground, and hold up to Texas winds. All the portable setups I have seen have a dinky little tripod for the antenna, and you know it wouldn't take long for one of those to fly to Oklahoma.
73,
Brett
Reactions: Riverman
At one time I had both Wolf River coil and an Antron 99. Kicking myself for not having the idea at the time to combine the two. :confused:
Reactions: 2RT307
