"Another look at the Imax:"
every antenna is a dipole, if it isn't it doesn't radiate, not very efficiently anyway. balanced currents in both "poles" and elimination of common mode current on the feedline and the support structure is a must in any properly designed antenna system. while i don't voice it as often as i once did, low feedpoint heights, feedline and support structure radiation are the main culprits in most tvi and interference situations. in the case of my own antenna systems i make extensive use of baluns, radials and antenna tuners, even with such antennas as the "glass sticks" like the A99 and others and i really don't worry about rf earth-ground returns for antennas that are properly balanced and decoupled. come to think of it, swr is usually the last thing i worry about after poles, (two halves of the antenna) feedline and support current measurements and making sure that the transmitter is always looking into what it takes to keep it happy.
it's not too difficult to understand why most operators fail to realize any benefit from elevated radial systems (or add-on radial kits) when you stop for a moment and ask yourself if there is any antenna current present in the radial system to begin with. if the current has disappeared into the feed and support then what's left for the radials? unfortunately in the majority of cases, there's a lot more involved to proper antenna design and installation than just throwing up the latest entry on the market, adjusting for min. swr and flipping the switch and you and others here know that.
there are two things that can be done to insure the presence of current-as-charge in the added radial system for it to function properly. installing a current choke or a 1:1 current balun will create a high impedance reducing or eliminating common-mode currents on the outer shield of the feedline. the second thing that can be done is to insulate the antenna from the mast or support structure.
once these steps are accomplished the charge-as-current has no choice but to fill the radials with charge when they are added. the ultimate goal is to produce half of the total current generated at the feedpoint in the main radiator and to have the other half divided up evenly among the total number of radial elements.
ideally ALL common-mode current must flow in the radial system for it to function properly.
