Carl said:get a amp meter and a volt meter. bring a little calculator. amps x volts x.70 (as a balpark 70% effency, most are around 50%)
12.8v (most common charging voltage under 3800rpm) x 24amp draw = 307.2 watts at 100% efficency
307.2 x .70 (70%) = 215.04 watts out.
about what a pair of 2879's use. i always get a kick out of it when people say 2 90 watt transistors do 400 watts.
only way your ever going to read true output accuratly other than a scope.
Toshiba 2SC2879s are rated at 100 watts. I have seen a 2 x 2879 amp driven by a 2 x 2290 swing a Bird 43P a little over 500 watts peak at 14 volts into a dummy load. At 18 volts a 2 pill will 900+ watts peak. Not what the designers at Toshiba had in mind but they'll do it in the right amps when having the snot driven out of them. Whether this gives a chuckle or not it is the truth.:idea:
