Is the Sirio Gain Master really a good DX vertical ?
Many vertical antennas can work well close to the ground. However, once you mount an 11 meter horizontal 5 feet off the ground, you have lost most of the horizontal component and directional characteristics. The close ground reflections force the signal up into the vertical plane.
Just for clarification, Are you are referring to a beam antenna mounted horizontally 5 feet off the ground? If so, Why? Because most people I know mount their horizontal orientated antenna higher than just 5 feet. Thanks.
Hello Shockwave: Is this elevation angle info measured data? Or maybe computer generated data??
Reactions: Marconi
I'm not sure where this is documented but anytime I've placed a dipole on this band that low to the ground, it was sensitive to signals from more than just the broadside directions and also gained vertical sensitivity at the loss of horizontal signal. On that note, all I have to go on is memory here so if someone has had a similar or different experience, please share.
I found this at the ARRL dot ORG site but it was referring to a horizontal antenna over flat ground
"The dipole is a straight length of wire (or tubing) into which radio-frequency energy is fed at the center. Because of its simplicity, the dipole may be easily subjected to theoretical performance analyses. Further, the results of proper analyses are well borne out in practice. For these reasons, the half-wave dipole is a convenient performance standard against which other antenna systems can be compared. Because the earth acts as a reflector for HF radio waves, the directive properties of any antenna are modified considerably by the ground underneath it. If a dipole antenna is placed horizontally above the ground, most of the energy radiated downward from the dipole is
reflected upward. The reflected waves combine with the direct waves (those radiated at angles above the horizontal) in various ways, depending on the height of the antenna, the frequency, and the electrical characteristics of the ground under and around the antenna. At some vertical angles above the horizon, the direct and reflected waves may be exactly in phase—that is, the maximum signal or field strengths of both waves are reached at the same instant at some distant point. In this case the resultant field strength is equal to the sum of the two components. At other vertical angles the two waves may be completely out of phase at some distant point—that is, the fields are maximum at the same instant but the phase directions are opposite. The resultant field strength in this case is the difference between the two. At still other angles the resultant field will have intermediate values. Thus, the effect of the ground is to increase the intensity of radiation at some vertical angles and to decrease it at others. The elevation angles at which the maxima and minima occur depend primarily on the antenna height above ground. (The electrical characteristics of the ground have some slight effect too.)"
Reference https://www.arrl.org/files/file/antplnr.pdf
You can scroll down to page 5 under Horizontal Antennas Over Flat Ground
Well that explains why there are so many variables and different results with this. It just depends on where you are talking and how the direct and reflected signals are in alignment (or not) at that location. Thanks for providing additional information on the subject too.
Reactions: Unit 75
Since this thread popped up again I'll add this - the other day I pulled out my Gain Master and set it up to do some testing by attaching it to a piece of pipe and leaning it against the gutter. SWR was 1.2. I laid it on the ground afterwards and then went inside.
Next day I came out to do some more testing and about 10 minutes in I noticed my SWR was 1.5 which was weird. I peeked outside and forgot I had left the antenna lying on the ground.
I've testing a ton of vertical antennas and I can't ever remember one that had a 1.5 SWR while lying on gravel right next to the house. Even with it leaning up against the gutter and only 1/2 the antenna being higher than the house I was able to talk to someone 30 miles away who said I was coming in very loud.
I've been very impressed with this antenna and I've taken it apart and put it back together 10 times or so and it's still holding up - I think it's 5 or 6 years old now? Maybe even older. I got mine right when they first came out.
I'm all Maki bro. Don't know how to navigate this site. I fell dumb. Thanks for response. Buddy I'm lost on posting, or anything. I do have radio probs. dont want to be rude to the site
Good replies as always.
I put a 1/2 decent signal into Lombok Island Indonesia with the Gain Master and 160W PEP today (Bruno) I think he could be classed a power station he was giving me a signal 9, booming in this morning. (about 7,600 miles distance)
Good ole Bruno, I have talked with him and his wife Luna several times, she is one funny lady on the radio!!
Reactions: 2NC995
I have a few friends that use Gainmasters. I can talk the same dx with my Imax.
The gain master has beaten alot of 5/8 vertical and people still don't believe how good it is.
Put it up against a maco 3 element on the vertical side then after it beats it then leave it alone.
Great antenna. Only problem is they don’t like Oklahoma wind. I came home from work one day and mine was broken at the lower shaft. Coax was all twisted up and damaged before I could get it down. Sad day
Reactions: Slowmover
