I've just about had it with Internet Explorer
Lenovo laptops running IE8 experience scrolling problems. :headbang
Lenovo laptops running FF do not. :thumbup1:
I will never get used to the bookmarks in FF, don't know why other than I am an old fart used to using IE.
Chrome uninstalled without a problem. I used the Windows uninstaller. I like Firefox the best. I have used it right after it came out .
When I uninstalled it none of my previous shortcuts would work and forget about clicking on a link, totally screwed my registry.
Before you shoot flaming arrows at browsers, consider how good is your code?
The first page of this thread has a lot of nonconformances. Some browsers handle bad programming better than others, but I feel this is an attribute that should not be used as a solution to problems.
Code:
 Markup Validation Service
Check the markup (HTML, XHTML, …) of Web documents
Jump To:Validation Output
Errors found while checking this document as XHTML 1.0 Transitional!
Result: 128 Errors, 70 warning(s)
Address:
Encoding: iso-8859-1  (detect automatically) utf-8 (Unicode, worldwide) utf-16 (Unicode, worldwide) iso-8859-1 (Western Europe) iso-8859-2 (Central Europe) iso-8859-3 (Southern Europe) iso-8859-4 (North European) iso-8859-5 (Cyrillic) iso-8859-6-i (Arabic) iso-8859-7 (Greek) iso-8859-8 (Hebrew, visual) iso-8859-8-i (Hebrew, logical) iso-8859-9 (Turkish) iso-8859-10 (Latin 6) iso-8859-11 (Latin/Thai) iso-8859-13 (Latin 7, Baltic Rim) iso-8859-14 (Latin 8, Celtic) iso-8859-15 (Latin 9) iso-8859-16 (Latin 10) us-ascii (basic English) euc-jp (Japanese, Unix) shift_jis (Japanese, Win/Mac) iso-2022-jp (Japanese, email) euc-kr (Korean) gb2312 (Chinese, simplified) gb18030 (Chinese, simplified) big5 (Chinese, traditional) Big5-HKSCS (Chinese, Hong Kong) tis-620 (Thai) koi8-r (Russian) koi8-u (Ukrainian) iso-ir-111 (Cyrillic KOI-8) macintosh (MacRoman) windows-1250 (Central Europe) windows-1251 (Cyrillic) windows-1252 (Western Europe) windows-1253 (Greek) windows-1254 (Turkish) windows-1255 (Hebrew) windows-1256 (Arabic) windows-1257 (Baltic Rim)
Doctype: XHTML 1.0 Transitional  (detect automatically) HTML5 (experimental) XHTML 1.0 Strict XHTML 1.0 Transitional XHTML 1.0 Frameset HTML 4.01 Strict HTML 4.01 Transitional HTML 4.01 Frameset HTML 3.2 HTML 2.0 ISO/IEC 15445:2000 ("ISO HTML") XHTML 1.1 XHTML + RDFa XHTML Basic 1.0 XHTML Basic 1.1 XHTML Mobile Profile 1.2 XHTML-Print 1.0 XHTML 1.1 plus MathML 2.0 XHTML 1.1 plus MathML 2.0 plus SVG 1.1 MathML 2.0 SVG 1.0 SVG 1.1 SVG 1.1 Tiny SVG 1.1 Basic SMIL 1.0 SMIL 2.0
Root Element: html
Root Namespace: http://www.w3.org/1999/xhtml
The W3C validators rely on community support for hosting and development.
Donate and help us build better tools for a better web.
OptionsShow Source Show Outline List Messages Sequentially Group Error Messages by Type
Validate error pages Verbose Output Clean up Markup with HTML Tidy
Help on the options is available.
↑ Top
Validation Output: 128 Errors
 Line 318, Column 568: Attribute "REL" is not a valid attribute. Did you mean "rel"?
…=RSS2&amp;forumids=73" /> <LINK REL="SHORTCUT ICON" HREF="/favicon.ico"> <tit✉
You have used the attribute named above in your document, but the document type you are using does not support that attribute for this element. This error is often caused by incorrect use of the "Strict" document type with a document that uses frames (e.g. you must use the "Transitional" document type to get the "target" attribute), or by using vendor proprietary extensions such as "marginheight" (this is usually fixed by using CSS to achieve the desired effect instead).
This error may also result if the element itself is not supported in the document type you are using, as an undefined element will have no supported attributes; in this case, see the element-undefined error message for further information.
How to fix: check the spelling and case of the element and attribute, (Remember XHTML is all lower-case) and/or check that they are both allowed in the chosen document type, and/or use CSS instead of this attribute. If you received this error when using the <embed> element to incorporate flash media in a Web page, see the FAQ item on valid flash.
 Line 318, Column 589: Attribute "HREF" is not a valid attribute. Did you mean "href"?
…" /> <LINK REL="SHORTCUT ICON" HREF="/favicon.ico"> <title> I've just about h✉
 Line 318, Column 603: element "LINK" undefined. Did you mean "link"?
…="SHORTCUT ICON" HREF="/favicon.ico"> <title> I've just about had it with Int✉
You have used the element named above in your document, but the document type you are using does not define an element of that name. This error is often caused by:
•incorrect use of the "Strict" document type with a document that uses frames (e.g. you must use the "Frameset" document type to get the "<frameset>" element),
•by using vendor proprietary extensions such as "<spacer>" or "<marquee>" (this is usually fixed by using CSS to achieve the desired effect instead).
•by using upper-case tags in XHTML (in XHTML attributes and elements must be all lower-case).
 Line 326, Column 21: end tag for "LINK" omitted, but OMITTAG NO was specified
	--> </style> </head> <body onload="">  <a name="top"></a> <table border="0" wid✉
You may have neglected to close an element, or perhaps you meant to "self-close" an element, that is, ending it with "/>" instead of ">".
 Line 318, Column 557: start tag was here
…al.php?type=RSS2&amp;forumids=73" /> <LINK REL="SHORTCUT ICON" HREF="/favicon Line 326, Column 21: end tag for "head" which is not finished
Most likely, you nested tags and closed them in the wrong order. For example <p><em>...</p> is not acceptable, as <em> must be closed before <p>. Acceptable nesting is: <p><em>...</em></p>
Another possibility is that you used an element which requires a child element that you did not include. Hence the parent element is "not finished", not complete. For instance, in HTML the <head> element must contain a <title> child element, lists (ul, ol, dl) require list items (li, or dt, dd), and so on.
 Line 326, Column 399: end tag for "center" omitted, but OMITTAG NO was specified
…="header_right_cell"> <center>  </td> </tr> </table>    <div align="center"> ✉
 Line 326, Column 384: start tag was here
…lign="right" id="header_right_cell"> <center>  </td> </tr> </table>    <div a Line 336, Column 1367: Attribute "method" exists, but can not be used for this element.
…class="vbmenu_control"><FORM method="GET" action="http://www.qrz.com/callsign✉
 Line 336, Column 1380: Attribute "action" exists, but can not be used for this element.
…_control"><FORM method="GET" action="http://www.qrz.com/callsign.html" target✉
 Line 336, Column 1422: Attribute "target" exists, but can not be used for this element.
…//www.qrz.com/callsign.html" target="_blank"> <INPUT type="text" name="callsi✉
 Line 336, Column 1430: element "FORM" undefined. Did you mean "form"?
…z.com/callsign.html" target="_blank"> <INPUT type="text" name="callsign" size✉
 Line 336, Column 1444: Attribute "type" exists, but can not be used for this element.
….html" target="_blank"> <INPUT type="text" name="callsign" size="5" style="fo✉
 Line 336, Column 1456: Attribute "name" exists, but can not be used for this element.
…t="_blank"> <INPUT type="text" name="callsign" size="5" style="font-size:8pt"✉
 Line 336, Column 1472: Attribute "size" exists, but can not be used for this element.
…UT type="text" name="callsign" size="5" style="font-size:8pt"> <INPUT type="s✉
 Line 336, Column 1482: Attribute "style" exists, but can not be used for this element.
…ext" name="callsign" size="5" style="font-size:8pt"> <INPUT type="submit" val✉
 Line 336, Column 1497: element "INPUT" undefined. Did you mean "input"?
…sign" size="5" style="font-size:8pt"> <INPUT type="submit" value="Callsign" s✉
 Line 336, Column 1526: Attribute "value" exists, but can not be used for this element.
…ze:8pt"> <INPUT type="submit" value="Callsign" style="font-size:8pt"></FORM> ✉
 Line 336, Column 1558: element "INPUT" undefined. Did you mean "input"?
…lue="Callsign" style="font-size:8pt"></FORM>  </tr> </table> </div> <table wi✉
 Line 336, Column 1565: end tag for "INPUT" omitted, but OMITTAG NO was specified
…llsign" style="font-size:8pt"></FORM>  </tr> </table> </div> <table width="10✉
 Line 336, Column 1498: start tag was here
…ign" size="5" style="font-size:8pt"> <INPUT type="submit" value="Callsign" st Line 336, Column 1565: end tag for "INPUT" omitted, but OMITTAG NO was specified
 Line 336, Column 1431: start tag was here
….com/callsign.html" target="_blank"> <INPUT type="text" name="callsign" size= Line 336, Column 1572: end tag for "td" omitted, but OMITTAG NO was specified
… style="font-size:8pt"></FORM>  </tr> </table> </div> <table width="100%" cel✉
 Line 336, Column 1326: start tag was here
…nofollow">Mark Forums Read</a></td>  <td class="vbmenu_control"><FORM method= Line 336, Column 1729: document type does not allow element "td" here; assuming missing "tr" start-tag
… /> <div align="center"> <table> <td> <script type="text/javascript"><!--✉
 Line 350, Column 87: end tag for "tr" omitted, but OMITTAG NO was specified
…how_ads.js"> </script> </td> </table> </div> <h2 class="h2">I've just about h✉
 Line 336, Column 1725: start tag was here
… <br /> <div align="center"> <table> <td> <script type="text/javascript"><!-- Line 375, Column 84: end tag for "br" omitted, but OMITTAG NO was specified
…d/show_ads.js"> </script></div> <br> <!-- google_ad_section_start -->I've bee✉
 Line 375, Column 79: start tag was here
…pagead/show_ads.js"> </script></div> <br> <!-- google_ad_section_start -->I'v Line 555, Column 5596: end tag for "br" omitted, but OMITTAG NO was specified
…x_tagsugg.js?v=374"></script>   <br> <div align="center"> <table> <td> <scrip✉
 Line 555, Column 5591: start tag was here
…n_ajax_tagsugg.js?v=374"></script>   <br> <div align="center"> <table> <td> < Line 555, Column 5629: document type does not allow element "td" here; assuming missing "tr" start-tag
…br> <div align="center"> <table> <td> <script src='http://adn.ebay.com/files/✉
 Line 555, Column 5703: required attribute "type" not specified
…es/js/min/ebay_activeContent-min.js'></script> <script src='http://adn.ebay.c✉
The attribute given above is required for an element that you've used, but you have omitted it. For instance, in most HTML and XHTML document types the "type" attribute is required on the "script" element and the "alt" attribute is required for the "img" element.
Typical values for type are type="text/css" for <style> and type="text/javascript" for <script>.
 Line 555, Column 5762: cannot generate system identifier for general entity "campId"
…'http://adn.ebay.com/cb?programId=1&campId=5336136228&toolId=10026&keyword=ic✉
An entity reference was found in the document, but there is no reference by that name defined. Often this is caused by misspelling the reference name, unencoded ampersands, or by leaving off the trailing semicolon (;). The most common cause of this error is unencoded ampersands in URLs as described by the WDG in "Ampersands in URLs".
Entity references start with an ampersand (&) and end with a semicolon (;). If you want to use a literal ampersand in your document you must encode it as "&amp;" (even inside URLs!). Be careful to end entity references with a semicolon or your entity reference may get interpreted in connection with the following text. Also keep in mind that named entity references are case-sensitive; &Aelig; and &aelig; are different characters.
If this error appears in some markup generated by PHP's session handling code, this article has explanations and solutions to your problem.
Note that in most documents, errors related to entity references will trigger up to 5 separate messages from the Validator. Usually these will all disappear when the original problem is fixed.
 Line 555, Column 5762: general entity "campId" not defined and no default entity
This is usually a cascading error caused by a an undefined entity reference or use of an unencoded ampersand (&) in an URL or body text. See the previous message for further details.
 Line 555, Column 5768: reference not terminated by REFC delimiter
…//adn.ebay.com/cb?programId=1&campId=5336136228&toolId=10026&keyword=icom&cat✉
If you meant to include an entity that starts with "&", then you should terminate it with ";". Another reason for this error message is that you inadvertently created an entity by failing to escape an "&" character just before this text.
 Line 555, Column 5768: reference to external entity in attribute value
This is generally the sign of an ampersand that was not properly escaped for inclusion in an attribute, in a href for example. You will need to escape all instances of '&' into '&amp;'.
 Line 555, Column 5768: reference to entity "campId" for which no system identifier could be generated
 Line 555, Column 5760: entity was defined here
…c='http://adn.ebay.com/cb?programId=1&campId=5336136228&toolId=10026&keyword= Line 555, Column 5780: cannot generate system identifier for general entity "toolId"
…om/cb?programId=1&campId=5336136228&toolId=10026&keyword=icom&catId=163856&so✉
 Line 555, Column 5780: general entity "toolId" not defined and no default entity
 Line 555, Column 5786: reference not terminated by REFC delimiter
…programId=1&campId=5336136228&toolId=10026&keyword=icom&catId=163856&sortBy=2✉
 Line 555, Column 5786: reference to external entity in attribute value
 Line 555, Column 5786: reference to entity "toolId" for which no system identifier could be generated
 Line 555, Column 5778: entity was defined here
….com/cb?programId=1&campId=5336136228&toolId=10026&keyword=icom&catId=163856& Line 555, Column 5793: cannot generate system identifier for general entity "keyword"
…Id=1&campId=5336136228&toolId=10026&keyword=icom&catId=163856&sortBy=2&showIt✉
 Line 555, Column 5793: general entity "keyword" not defined and no default entity
 Line 555, Column 5800: reference not terminated by REFC delimiter
…mpId=5336136228&toolId=10026&keyword=icom&catId=163856&sortBy=2&showItems=1&w✉
 Line 555, Column 5800: reference to external entity in attribute value
 Line 555, Column 5800: reference to entity "keyword" for which no system identifier could be generated
 Line 555, Column 5791: entity was defined here
…amId=1&campId=5336136228&toolId=10026&keyword=icom&catId=163856&sortBy=2&show Line 555, Column 5806: cannot generate system identifier for general entity "catId"
…336136228&toolId=10026&keyword=icom&catId=163856&sortBy=2&showItems=1&width=3✉
 Line 555, Column 5806: general entity "catId" not defined and no default entity
 Line 555, Column 5811: reference not terminated by REFC delimiter
…6228&toolId=10026&keyword=icom&catId=163856&sortBy=2&showItems=1&width=360&he✉
 Line 555, Column 5811: reference to external entity in attribute value
 Line 555, Column 5811: reference to entity "catId" for which no system identifier could be generated
 Line 555, Column 5804: entity was defined here
…=5336136228&toolId=10026&keyword=icom&catId=163856&sortBy=2&showItems=1&width Line 555, Column 5819: cannot generate system identifier for general entity "sortBy"
…lId=10026&keyword=icom&catId=163856&sortBy=2&showItems=1&width=360&height=205✉
 Line 555, Column 5819: general entity "sortBy" not defined and no default entity
 Line 555, Column 5825: reference not terminated by REFC delimiter
…026&keyword=icom&catId=163856&sortBy=2&showItems=1&width=360&height=205&font=✉
 Line 555, Column 5825: reference to external entity in attribute value
 Line 555, Column 5825: reference to entity "sortBy" for which no system identifier could be generated
 Line 555, Column 5817: entity was defined here
…oolId=10026&keyword=icom&catId=163856&sortBy=2&showItems=1&width=360&height=2 Line 555, Column 5828: cannot generate system identifier for general entity "showItems"
…&keyword=icom&catId=163856&sortBy=2&showItems=1&width=360&height=205&font=4&t✉
 Line 555, Column 5828: general entity "showItems" not defined and no default entity
 Line 555, Column 5837: reference not terminated by REFC delimiter
…icom&catId=163856&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=✉
 Line 555, Column 5837: reference to external entity in attribute value
 Line 555, Column 5837: reference to entity "showItems" for which no system identifier could be generated
 Line 555, Column 5826: entity was defined here
…26&keyword=icom&catId=163856&sortBy=2&showItems=1&width=360&height=205&font=4 Line 555, Column 5840: cannot generate system identifier for general entity "width"
…m&catId=163856&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=333✉
 Line 555, Column 5840: general entity "width" not defined and no default entity
 Line 555, Column 5845: reference not terminated by REFC delimiter
…Id=163856&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=333366&l✉
 Line 555, Column 5845: reference to external entity in attribute value
 Line 555, Column 5845: reference to entity "width" for which no system identifier could be generated
 Line 555, Column 5838: entity was defined here
…com&catId=163856&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=3 Line 555, Column 5850: cannot generate system identifier for general entity "height"
…3856&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=333366&linkCo✉
 Line 555, Column 5850: general entity "height" not defined and no default entity
 Line 555, Column 5856: reference not terminated by REFC delimiter
…ortBy=2&showItems=1&width=360&height=205&font=4&textColor=333366&linkColor=33✉
 Line 555, Column 5856: reference to external entity in attribute value
 Line 555, Column 5856: reference to entity "height" for which no system identifier could be generated
 Line 555, Column 5848: entity was defined here
…163856&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=333366&link Line 555, Column 5861: cannot generate system identifier for general entity "font"
…=2&showItems=1&width=360&height=205&font=4&textColor=333366&linkColor=333333&✉
 Line 555, Column 5861: general entity "font" not defined and no default entity
 Line 555, Column 5865: reference not terminated by REFC delimiter
…howItems=1&width=360&height=205&font=4&textColor=333366&linkColor=333333&arro✉
 Line 555, Column 5865: reference to external entity in attribute value
 Line 555, Column 5865: reference to entity "font" for which no system identifier could be generated
 Line 555, Column 5859: entity was defined here
…By=2&showItems=1&width=360&height=205&font=4&textColor=333366&linkColor=33333 Line 555, Column 5868: cannot generate system identifier for general entity "textColor"
…Items=1&width=360&height=205&font=4&textColor=333366&linkColor=333333&arrowCo✉
 Line 555, Column 5868: general entity "textColor" not defined and no default entity
 Line 555, Column 5877: reference not terminated by REFC delimiter
…idth=360&height=205&font=4&textColor=333366&linkColor=333333&arrowColor=FFAF5✉
 Line 555, Column 5877: reference to external entity in attribute value
 Line 555, Column 5877: reference to entity "textColor" for which no system identifier could be generated
 Line 555, Column 5866: entity was defined here
…owItems=1&width=360&height=205&font=4&textColor=333366&linkColor=333333&arrow Line 555, Column 5885: cannot generate system identifier for general entity "linkColor"
…&height=205&font=4&textColor=333366&linkColor=333333&arrowColor=FFAF5E&color1✉
 Line 555, Column 5885: general entity "linkColor" not defined and no default entity
 Line 555, Column 5894: reference not terminated by REFC delimiter
…05&font=4&textColor=333366&linkColor=333333&arrowColor=FFAF5E&color1=738fbf&c✉
 Line 555, Column 5894: reference to external entity in attribute value
 Line 555, Column 5894: reference to entity "linkColor" for which no system identifier could be generated
 Line 555, Column 5883: entity was defined here
…60&height=205&font=4&textColor=333366&linkColor=333333&arrowColor=FFAF5E&colo Line 555, Column 5902: cannot generate system identifier for general entity "arrowColor"
…4&textColor=333366&linkColor=333333&arrowColor=FFAF5E&color1=738fbf&color2=F5✉
 Line 555, Column 5902: general entity "arrowColor" not defined and no default entity
 Line 555, Column 5912: reference not terminated by REFC delimiter
…r=333366&linkColor=333333&arrowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></sc✉
 Line 555, Column 5912: reference to external entity in attribute value
 Line 555, Column 5912: reference to entity "arrowColor" for which no system identifier could be generated
 Line 555, Column 5900: entity was defined here
…t=4&textColor=333366&linkColor=333333&arrowColor=FFAF5E&color1=738fbf&color2= Line 555, Column 5920: cannot generate system identifier for general entity "color1"
…&linkColor=333333&arrowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </✉
 Line 555, Column 5920: general entity "color1" not defined and no default entity
 Line 555, Column 5926: reference not terminated by REFC delimiter
…olor=333333&arrowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </td> <t✉
 Line 555, Column 5926: reference to external entity in attribute value
 Line 555, Column 5926: reference to entity "color1" for which no system identifier could be generated
 Line 555, Column 5918: entity was defined here
…66&linkColor=333333&arrowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script>  Line 555, Column 5934: cannot generate system identifier for general entity "color2"
…333&arrowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </td> <td> <scri✉
 Line 555, Column 5934: general entity "color2" not defined and no default entity
 Line 555, Column 5940: reference not terminated by REFC delimiter
…rowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </td> <td> <script src✉
 Line 555, Column 5940: reference to external entity in attribute value
 Line 555, Column 5940: reference to entity "color2" for which no system identifier could be generated
 Line 555, Column 5932: entity was defined here
…33333&arrowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </td> <td> <sc Line 555, Column 5948: required attribute "type" not specified
…=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </td> <td> <script src='http:/✉
 Line 555, Column 6042: required attribute "type" not specified
 Line 555, Column 6107: reference not terminated by REFC delimiter
…//adn.ebay.com/cb?programId=1&campId=5336136228&toolId=10026&keyword=yaesu&ca✉
 Line 555, Column 6107: reference to external entity in attribute value
 Line 555, Column 6107: reference to entity "campId" for which no system identifier could be generated
…c='http://adn.ebay.com/cb?programId=1&campId=5336136228&toolId=10026&keyword= Line 555, Column 6125: reference not terminated by REFC delimiter
…programId=1&campId=5336136228&toolId=10026&keyword=yaesu&catId=163855&sortBy=✉
 Line 555, Column 6125: reference to external entity in attribute value
 Line 555, Column 6125: reference to entity "toolId" for which no system identifier could be generated
….com/cb?programId=1&campId=5336136228&toolId=10026&keyword=icom&catId=163856& Line 555, Column 6139: reference not terminated by REFC delimiter
…mpId=5336136228&toolId=10026&keyword=yaesu&catId=163855&sortBy=2&showItems=1&✉
 Line 555, Column 6139: reference to external entity in attribute value
 Line 555, Column 6139: reference to entity "keyword" for which no system identifier could be generated
…amId=1&campId=5336136228&toolId=10026&keyword=icom&catId=163856&sortBy=2&show Line 555, Column 6151: reference not terminated by REFC delimiter
…228&toolId=10026&keyword=yaesu&catId=163855&sortBy=2&showItems=1&width=360&he✉
 Line 555, Column 6151: reference to external entity in attribute value
 Line 555, Column 6151: reference to entity "catId" for which no system identifier could be generated
…=5336136228&toolId=10026&keyword=icom&catId=163856&sortBy=2&showItems=1&width Line 555, Column 6165: reference not terminated by REFC delimiter
…26&keyword=yaesu&catId=163855&sortBy=2&showItems=1&width=360&height=205&font=✉
 Line 555, Column 6165: reference to external entity in attribute value
 Line 555, Column 6165: reference to entity "sortBy" for which no system identifier could be generated
…oolId=10026&keyword=icom&catId=163856&sortBy=2&showItems=1&width=360&height=2 Line 555, Column 6177: reference not terminated by REFC delimiter
…aesu&catId=163855&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=✉
 Line 555, Column 6177: reference to external entity in attribute value
 Line 555, Column 6177: reference to entity "showItems" for which no system identifier could be generated
…26&keyword=icom&catId=163856&sortBy=2&showItems=1&width=360&height=205&font=4 Line 555, Column 6185: reference not terminated by REFC delimiter
…Id=163855&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=333366&l✉
 Line 555, Column 6185: reference to external entity in attribute value
 Line 555, Column 6185: reference to entity "width" for which no system identifier could be generated
…com&catId=163856&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=3 Line 555, Column 6196: reference not terminated by REFC delimiter
 Line 555, Column 6196: reference to external entity in attribute value
 Line 555, Column 6196: reference to entity "height" for which no system identifier could be generated
…163856&sortBy=2&showItems=1&width=360&height=205&font=4&textColor=333366&link Line 555, Column 6205: reference not terminated by REFC delimiter
 Line 555, Column 6205: reference to external entity in attribute value
 Line 555, Column 6205: reference to entity "font" for which no system identifier could be generated
…By=2&showItems=1&width=360&height=205&font=4&textColor=333366&linkColor=33333 Line 555, Column 6217: reference not terminated by REFC delimiter
 Line 555, Column 6217: reference to external entity in attribute value
 Line 555, Column 6217: reference to entity "textColor" for which no system identifier could be generated
…owItems=1&width=360&height=205&font=4&textColor=333366&linkColor=333333&arrow Line 555, Column 6234: reference not terminated by REFC delimiter
 Line 555, Column 6234: reference to external entity in attribute value
 Line 555, Column 6234: reference to entity "linkColor" for which no system identifier could be generated
…60&height=205&font=4&textColor=333366&linkColor=333333&arrowColor=FFAF5E&colo Line 555, Column 6252: reference not terminated by REFC delimiter
 Line 555, Column 6252: reference to external entity in attribute value
 Line 555, Column 6252: reference to entity "arrowColor" for which no system identifier could be generated
…t=4&textColor=333366&linkColor=333333&arrowColor=FFAF5E&color1=738fbf&color2= Line 555, Column 6266: reference not terminated by REFC delimiter
…olor=333333&arrowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </td> </✉
 Line 555, Column 6266: reference to external entity in attribute value
 Line 555, Column 6266: reference to entity "color1" for which no system identifier could be generated
…66&linkColor=333333&arrowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script>  Line 555, Column 6280: reference not terminated by REFC delimiter
…rowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </td> </table> </div> ✉
 Line 555, Column 6280: reference to external entity in attribute value
 Line 555, Column 6280: reference to entity "color2" for which no system identifier could be generated
…33333&arrowColor=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </td> <td> <sc Line 555, Column 6288: required attribute "type" not specified
…=FFAF5E&color1=738fbf&color2=F5F5FF'></script> </td> </table> </div>  <br /> ✉
 Line 555, Column 6312: end tag for "tr" omitted, but OMITTAG NO was specified
…lor2=F5F5FF'></script> </td> </table> </div>  <br /> <div class="smallfont" a✉
 Line 555, Column 5625: start tag was here
…   <br> <div align="center"> <table> <td> <script src='http://adn.ebay.com/fi Line 326, Column 21: XML Parsing Error: Opening and ending tag mismatch: LINK line 318 and head
 Line 326, Column > 80: XML Parsing Error: Opening and ending tag mismatch: center line 326 and td
…name="top"></a> <table border="0" width="100%" cellpadding="0" cellspacing="0…✉
 Line 326, Column > 80: XML Parsing Error: Opening and ending tag mismatch: td line 326 and tr
 Line 326, Column > 80: XML Parsing Error: Opening and ending tag mismatch: tr line 326 and table
 Line 336, Column > 80: XML Parsing Error: Opening and ending tag mismatch: INPUT line 336 and FORM
…pagead/show_ads.js"> </script> </div>  <div class="tborder" style="padding:1p…✉
 Line 336, Column > 80: XML Parsing Error: Opening and ending tag mismatch: INPUT line 336 and tr
 Line 336, Column > 80: XML Parsing Error: Opening and ending tag mismatch: FORM line 336 and table
 Line 336, Column > 80: XML Parsing Error: Opening and ending tag mismatch: td line 336 and div
 Line 378, Column > 80: XML Parsing Error: Opening and ending tag mismatch: br line 375 and div
…t a browser that doesn't have all of these issues?  I'm chasing my tail for m…✉
 Line 378, Column > 80: XML Parsing Error: Opening and ending tag mismatch: div line 368 and td
 Line 378, Column > 80: XML Parsing Error: Opening and ending tag mismatch: td line 368 and tr
 Line 378, Column > 80: XML Parsing Error: Opening and ending tag mismatch: tr line 368 and table
 Line 390, Column > 80: XML Parsing Error: Opening and ending tag mismatch: table line 353 and div
…pt" src="http://pagead2.googlesyndication.com/pagead/show_ads.js"> </script> …✉
 Line 555, Column > 80: XML Parsing Error: EntityRef: expecting ';'
…ldwidedx.com/images/smilies/wallbash.gif" border="0" alt="" title="headbang" …✉
 Line 559, Column > 80: XML Parsing Error: Opening and ending tag mismatch: br line 555 and td
…j_forumrules" style=""> <tr> <td class="alt1" nowrap="nowrap"><div class="sma…✉
 Line 559, Column > 80: XML Parsing Error: Opening and ending tag mismatch: div line 353 and tr
 Line 559, Column > 80: XML Parsing Error: Opening and ending tag mismatch: td line 336 and table
 Line 559, Column > 80: XML Parsing Error: Opening and ending tag mismatch: tr line 336 and div
 Line 559, Column > 80: XML Parsing Error: Opening and ending tag mismatch: table line 336 and div
 Line 601, Column 7: XML Parsing Error: Opening and ending tag mismatch: table line 336 and body
</body> </html>✉
 Line 601, Column 15: XML Parsing Error: Opening and ending tag mismatch: div line 336 and html
</body> </html>✉
 Line 601, Column 15: XML Parsing Error: Premature end of data in tag div line 326
</body> </html>✉
</body> </html>✉
</body> </html>✉
 Line 601, Column 15: XML Parsing Error: Premature end of data in tag table line 326
</body> </html>✉
 Line 601, Column 15: XML Parsing Error: Premature end of data in tag body line 326
</body> </html>✉
 Line 601, Column 15: XML Parsing Error: Premature end of data in tag head line 1
</body> </html>✉
 Line 601, Column 15: XML Parsing Error: Premature end of data in tag html line 1
</body> </html>✉
↑ Top
Home | About... | News | Docs | Help & FAQ | Feedback | Contribute |
This service runs the W3C Markup Validator, v0.8.5.
Copyright © 1994-2009 W3C® (MIT, ERCIM, Keio), All Rights Reserved. W3C liability, trademark, document use and software licensing rules apply. Your interactions with this site are in accordance with our public and Member privacy statements.
Just on a whim, I decided to bring up Firefox to see if the same things happen using that browser. To my surprise and shock, I don't have any of the same problems with the site using Firefox. The site is WAY faster. The "back" button bug is gone, the wierd slow response click issue is gone, all the "bugs" are gone using Firefox :headbang
I'm a Firefox convert now.
Yo GO Mo....but what took you so long? :crying:
I fly all over the board with Firefox and basic DSL. Only glitch I ever run across is occasionally when posting a reply, when the reply is SENT, instead of the usual posting and returning you to the thread, the screen quickly changes to a solid blank white page, says STOPPED in the lower left-hand corner while the FF Run Indicator Circle in the upper right-hand corner continues to alert rather than being stopped-finished. REFRESH gets the same results. The reply does go through but have to come back to the site anew to get back to the board.
I've been using FireFox for a few years now and between IE, Nutscrape, and this Mozilla product, it has been the best I have used. However there are certain websites that do not like FireFox, Facebook for one, and any message board hosted on YuKu, beyond that FireFox has been problem free, and fast....
I'm leery of Chrome. I stated earlier that when importing bookmarks from FF none of the other browsers could import the passwords. Not even Seamonkey which is designed by the makers of FF. But Google Chrome was able to get hold of the passwords.
  • @ unit_399:
