As you may know i have a home brew dual band J pole on my base. if i was to buy a NMO base mount and was to use my diamond CR320A on the base with my yaesu would i see more gain on RX and TX then running the j pole?
The Tri band base antennas are a little too much to spend and since i have multiple mobile antenna's...I would figure id save $$$ by using a Extra antenna
