J.R. radios or flamethrower?
I am looking forward to seeing radio 409's posts in other sections. New member has got to be busy catching up on what is happening here. :D
O.K. after further research I have found. Flamethrower radios are done by Sandman 500 So. California. J.R. Radios are done by J.R. himself and Bells cb shop has the famous Skrewdriver...Wonder if this is his name or the general census of what they do to their customers.
radio 409's signature:
409 Fontanna CA
Wonder if there is a connection? :whistle:
my FlameThrower rocks!
409 Fontanna CA
It's spelled "Fontana", not "Fontanna". There is a reason why most people in SoCal just refer to it as "Fontucky". No offense meant to anyone from that other State with a similar name :tt2:
Where are you guys getting your info?? The Flamethrower radio is NOT built by JR radio or screwdriver or (Skrewdriver) or sold by them. I own one, and it is built by sold Flamethrower only. I actually like the radio very much. Cost too much?? WTF? It is was between $25.-$ 37 LESS then what it would cost to have the local shop here after taxes and the ones I contaced on the internet to do the SAME MODS and upgrades listed on their add. The radio is a great way to go if you do not want to, or can't do the mods upgrades and Peak and Tweak alignment yourself.
I get great signal reports with it too. Audio is loud and powerfull. If you look there are a boatload of reviews on the internet about the Flamethrower radio. Most of them are VERY good. I think you guys are a bit too quick on the badmouth trigger, at least try one before you knock it. I shot skip with mine all the time, and NEVER had a BAD signal report on the audio or signal strength, dont know who you been talking to, but my FlameThrower rocks!
409 Fontanna CA
$250 for a radio that sells for $140 is a little over the top.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
