JB-150 Tube heating issue help!
443 -
I would stick with the 8417, as the amount of wattage gain with the EL34/6CA7 isn't really worth the effort. 73s.
- 399
There should be a wattage reduction, not gain with the EL34/6CA7 tube. Plate dissipation is not as high as the good old 8417. Problem is getting a decent 8417 tube, and I have a JB-200 that needs 2 new tubes, also originally 8417. Going to be completely rebuilding the JB 200 as a project.
I am wondering since the max plate current on the EL34/6CA7 appears to be only 140ma-200ma, could I use 4 EL34's, or 3-4 6CA7's in place of the original 2 8417's (314ma max plate current each). The transformer may hold it, may not. Guess if I go through the trouble of building the amp and it doesn't hold up to 4 tubes, I can get a new plate transformer, it would be worth the $80-$150 for the new transformer from surplus sales of NE or some equivalent place with good deals on plate transformers.
If I am looking at all the specs correctly, if my 8417 needs -36V bias to shut it off, then the EL34 or 6CA7 might need closer to -80V at the same plate voltages as the 8417.
Can someone who knows more about this swap or these tubes give me some help? I am a complete noob here to tubes.... And thanks for all the other help guys! My 150 is smokin'.
Question about the JB200.
In the attached schematic, it shows bias is applied as -120V in RX, and -36V in TX. Why is that? Would -36V not be enough to keep the tubes turned off in RX since it's 2 tubes vs just 1 of the same tubes in the JB150 which uses -36V on RX?
I just read where someone put a 6L6GC tube in a JB150... Looking at the specs it shows max plate voltage only 500V. Doesn't the JB150 run almost 800VDC on the plate? They said it worked fine.
Specs look like 6550 tube will drop right in, with none or just a little bias adjustment.
Someone take a look and let me know if you think it will work, I will get one and try it:
Added datasheet for 6550 (partial) had it in gif, but was too large 640x640 was too small couldn't read it so I just made it a pdf. Someone take a look and let me know what you think attached is 8417 datasheet too. Thanks to NJ7P for his cool tube database online.
I did that as an emergency-out-the-door job, it worked, the "Specs" did not make a difference.
ETA: You can find a lot more 6L6GC lying around than you can find 8417's and, at a better price.
Other tubes that work here are the 6550 and the new JJ-EL509 ($40) that was a TV sweep tube but has now been modified for improved use in audio applications with no plate cap. As has been pointed out many of these JB modulators have wiring problems with the bias circuit being reversed for receive. What's often not noticed is they put half the plate voltage on the screen and over dissipate the crap out of it with 400 volts!
Many only have a 2 pole relay that will not allow you to bias the tube into cutoff during receive. You should use a 3 pole relay so bias can be switched. Since the 400 volts on the screen is really way too much, we need to cut that back and shunt regulate the voltage with a 200 volt 5 watt zener fed through a 20K ohm 10 watt resistor.
To keep these parts from dissipating heat in receive, it's better to leave the bias fixed in TX and RX around -47 volts and switch your screen supply through the relay. Take the resistor feeding the zener and tube and connect it to the common relay terminal. The normally open contact goes to the 400 volt feed and ground the normally closed contact so the screen is "pulled" towards ground through the 20K resistor when in RX.
This keeps the tube in cutoff during RX and prevents the screen from melting during TX. Another real cheap tube that works good when you do these mods is the old 6DQ6B. You'll have to drill a hole to bring the plate connection up to the top cap and move 2 wires on the socket but at $8 for NOS on eBay, you can't beat it.
Even if the JB is wired correctly and has a 3 pole relay, it will still eat the tube alive in TX because of the 400 screen volts. Just key the mic and look at the tube. Not the outside plate either but the much more fragile screen wire under the plate. This will turn red almost as soon as you key. At the price of an 8417, you can't underestimate the importance of lowering this screen voltage.
Even with 200 volts on the screen and -40 volts on the control grid, the tube is still conducting because they have over 700 volts on the plate! To get the most modulator effect the tube should barley be conducting any idling current in TX so that the carrier has less amplification than the audio peaks. Since it runs in this non linear region between carrier and swing, it's not a linear at all.
You'll probably get best results keeping a constant -50 to -55 volts on the control grid and switching the new regulated 200 volts on the screen when in transmit. If the output is more than 10 watts dead carrier, adjust the screw on the back for 5 to 10 dead key. Some of the early models of these amps placed the front panel meter directly inline with the B+ high voltage and if the front plastic on the meter is broken, it can kill you if you touch it!
  • @ W4KVW:
  • @ W4KVW:
