July 1 - 4 Contest Rules
binrat
WDX Club Coordinator
Staff member
Nov 5, 2008
2,615
1,527
173
The Great White north
As per normal any errors or omissions, please let me know.
  • Only contacts with other WDX members count in the contest. The roster may be found as a sticky thread located http://www.worldwidedx.com/threads/wdx-roster-11-30-2014.28909/
  • Channels: 20-29 AM, 30-39 LSB
  • Date/Time: 0001 01July – 2359 04 July 2018 UTC. If you're not sure how UTC time works, check herehttp://www.timeanddate.com/worldclock/converter.html?p1=3875
  • Logs must be posted in the WDX Club Contest Contacts forum by the end of contest. Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest. The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread. At the end of the contest, the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
  • There is a 2x multiplier for mobile, portable, or maritime contacts. If you operate as mobile, maritime, or portable during the contest, you are credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. 3x multiplier for any contacts outside of CONUS and Canada. Make sure you clearly designate these in your log
  • No amplifiers allowed, CB legal limit.
  • Contacts will be verified against each others' logs
  • This is an "on your honor" contest and intended to be fun. Please play by the rule.
  • BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
I am not sure how many people participated. I tried a little and talked to some people but nobody from here. I tried the AM channels and the LSB as well. It seems that whenever the conditions would be good, there was too much traffic. Maybe next time we could do USB channels? I have never heard anyone contesting on 11m, but I have heard some on 75m before so that is the way I proceeded. I really didn't have a strategy, and I don't really know what I am doing but it was fun trying anyway.
  • @ Tim Chambers:
  • @ wavrider:
    sea que sea que,
