phases of the moonJust test, you will see impact of that.
I wonder what drives people to go for such problematic, low efficiency antenna.
Mike
Mike
This holds true for random wire set-up also, otherwise where is the other HALF of your antenna? Plus using half of an antenna and transmitting A/C what does that do for your efficiency ?
All the Best
Gary
Keep in mind that the link sp5it posted is for a different type of antenna, so most of the details are not the same. You can fold the antenna over on itself to adjust the length and see what it does. There are no exact dimensions for a wire like this so you may have to play with it a little.
I would like to at least get 40 Mtr. 80 mtr. is so good I can use it with out a tuner. 50 mtr. also. not making much sense. Also adding a second counterpoise did not do much.What bands are you shooting for?
