Justin tuned Delta Force
If I remember right, that radio has a high and low pot internally for the carrier. You just need to turn the variable all the way down, then adjust the low power pot. This will also affect the high power slightly, so you'll have to check both and also check modulation to find what works for you.
    Greg T has left the room.
