Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
Anyone out there ever try to key a 12v or 5 volt relay with a cobra 4 or 5 pin mic external to the radio.
Like doing a project that needs a relay to key it up when the mic is keyed. I have the circuit of a 1 second pulse to key the relay and shut back off in 1 second.
Problem is on the cobra 4 pin mics on pin 3 there is 8 volts and when the mic is keyed the voltage disappears. No Voltage and comes back when mic is released.
I need the opposite 8 volts when the mic is keyed and pulsed for the 1 second and shut off.
Like i mentioned i have the 1 second circuit a transistor capacitor resistor and relay works great with external power.
When I try on a 4 pin cobra mic like I mentioned the voltage problem needing the volts when radio is keyen and not in the receive mode.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
