KLV1000 blowing its fuse??
High Miler said:
I've been able to go with Svetlana EL-509's... Keep the Deadkey at 2 Watts swinging NO MORE than 5 Watts RMS... Or 15 Watts PEP .... And run the Amplifier Hot and heavy for 8 months now with no trouble...
The Amp still yields 650 watts RMS/ 1300 watts PEP and is very clean and great sounding when TUNED TO AUDIO... NOT by the way the book tells you!!!
When installing New tubes... Let them cook for 48 hours on standby, Run them on Low power for a week and than Medium for a couple days... Than run High power as needed...
Took a couple sets of tubes and some learning curves with this Amp... Follow the prescribed method above and you will get plenty of enjoyment on your radio... And with your KLV...
Here's a link for the tubes:
Svetlana EL-509 Heavy Duty Premium Tubes
I swear by them...
Since I repaired the tube socket, I am now seeing 1400watts peak :shock: out of my KLV1000 on high setting with a Bencher and B&W Low Pass filters on the output side of amp. These Russian tubes are nothing but the truth. I got mine from a seller in Russia . Total cost under $80 for new tubes shipped. I am happy :D
  • @ Mark Malcomb:
    Hello BJ. Been a long time since I've been on. You doing well? Mark Malcomb
  • @ Naysayer:
    I’m
  • @ kingmudduck:
