I've done a lot of board spraying in the day and any diode that is cracked is no good at least that has been my experience. Does the radio turn on but does not operate? Like no recieve or transmit?? Do you have a signal generator you have access to so if you were to tap components on the board while the generator is running you could see is the recieve changes??
