its not a problem of being accepeted or not. the bottom line is you cannot own one in the usa. they can be considered legal to use but YOU CANNOT OWN ONE!
if you cannot have one in your possession how can you use it.
they are classified as cb's, therefor they are required to follow the same rules.
dual use CB and amateur radios of the kind
at issue here may not be certificated under the Commission's
rules. Section 95.655(a) of the Rules5 states: ``. . . .
([CB] Transmitters with frequency capability for the Amateur
Radio Services . . . . will not be certificated.)'' See
also FCC 88-256, 1988 WL 488084 (August 17, 1988). This
clarification was added to explicitly foreclose the
possibility of certification of dual use CB and amateur
radios, see id., and thereby deter use by CB operators of
frequencies allocated for amateur radio use.
this is exactly why they are illegal to have in the us.
SUCH DEVICES VIOLATES THE
COMMUNICATIONS ACT OF 1934, AS AMENDED, AND THE COMMISSION'S RULES.
