I can start a flame fest from this but; It has to be mentioned because of Logistics, Economics - Manufacturing viability - and profitability.
There really is not a lot of differences amongst the MRF line in that package, they all use similar dies, I said SIMILAR - doesn't mean EXACT - so they had to design the die to make it mass production-able.
So that means many of them are nearly identical - expect for substrate - mountings and perhaps a special doping requirement for Mil-Spec operations we simply can't get into...
They are pretty much the same die in the Motorola - Signetics, Thompson and Toshiba and various others, differentiate their dies to enhance layers or aspects of performance for their benefit - but all are the same underneath that cap - only layout and the structure of it is different - but not by much.
So in light of performances between the die layouts - obviously many prefer the ones that are able to perform at twice the values they are rated for.
Well, that's great, but how is that obtained?
Bandwidth mostly.
Note the DUT schematics, all show one way or another the layout equals to the Frequency of Interest - usually the MUF (Maximum Useable Frequency) - so you see their "peaking" or test bench results at the 30MHz - or perhaps the 1MHz if it's needs a type of reproducible disastrous event or SWR measurements to attain their Conjugate values
Narrow the bandwidth, you can then idealize for the MAIN frequency you use it for - so now you know why they tend to "tweak" amps to attain those Gigawatt values Scotty always Save Kirks' Butt from those "Aliens" by having saved some type of power source in some console somewhere...
But I digress...
If you narrow the Bandwidth, you can improve the peak performance to get back some of that lost gain values from their (READ Maker) adaptation to make the Best of a Class C but try to make it Linear.
So review some of the changes in values - the circuit isn't much different, aside from missing the Bias - but look over the PARTS LIST's between and see the changes - they applied many to make the FM-based amp to work in AM - but to ask it to be SSB is possibly asking too much from that design.
Let's keep it simple.
This circuit looks VASTLY different than the 455
But study it - note there are similarities in functional "blocks"
They simply put in a tuning "tweak" support to help the end user
develop the proper platform and make the DUT work for their application.
- R1 isn't 10 ohms - it's 5.6 (5R6) 1/2W
- R2 and R3 are a divider - the VBB is set per your design specs - Diode is your business - they only want the VBB to be able to keep the device in AB mode - if it falls into C - it's only going to produce more IMD and heat - but if your ducks are in a row, it doesn't stay in the "C" Class all the time.
- The VBB setup is unique, you only need to set the CURRENT and note the "breakdown" Base voltage - so you can apply 4 volts (or slightly less) to attain the 50mA drive and leave it alone. If you use the Resistor values specified, and your Bias is less than 4V - you have set the part to drive for SSB mode. (Idle Current)
- If any of you have been paying attention, you don't need tons of AMPS to drive the bias, you should focus more on the input drive levels to make sure you don't cause the "Bias" to bottom out and force the Part into Class C.
- Why This Emphasis on Amps?
- Forcing your part to stay in Class AB, with more amperage
- - will actually PUSH the device into Class A operation
- and with more distortion and power dissipation as the result
- - remember what was said earlier about the RF rectification occurring at the Base of the DUT. It will make the BIAS climb - in this design, you now see why they provided a divider instead of a Diode - you need to drain the RF leaking in, as well as any DC level BIAS that results from the overdriven input. (Your Input Window drive level is key here - too much and BOOM on any device and any platform)
- In keeping the BIAS the same mA effort, your device; when it's exposed to higher levels of RF at the INPUT - will make the device operate more into Class C (Bias starvation) and all it's distortion and power dissipation - but the moment you lower the input values, Bias gets Restored - the admittance works and you obtain your Gain, clean up your signal and get less IMD from your Bias arrangement.
IF you decide to Go cheap, you may have to pay a price on the Pills and their Prescription costs - but if you need to use a Diode - then go ahead, you are simply applying that which is your business to offer some form of Regulation for the Bias supply in the first place. So Temperature compensation would be needed - might as well use it for that purpose - but also know, the DIODE's intrinsic impedance to the flow of power across it's junction is and will be different than Room Temperature.
So if you want to COMPENSATE - you may want to add a ZENER in, using a typical Power Regulator using a PNP transistor capable of 2A. You can also physically place the Zener close to the parts - BEFORE R2 - so it arrives to R2/R3 (Divider) as compensated. So include it in the circuit, but not going to ground - instead have it in the VBB Regulator SUPPLYING power to the DUT - like this...
Idle current would only be affected by the Voltage Drop of the Diode back at the Regulator - but thermally using the DUT or heat sink of the amp itself - as the thermal feedback.
