Nice read. And we’s a’gonna introduce you to paragraphs.
Sometimes i have trouble with the locked vs unlocked terminology. Just when I think I've got it I have doubts.
I'm of the thought that unless you're authoring a novel who really cares? I know I don't (obviously.) LOLNice read. And we’s a’gonna introduce you to paragraphs.
Show me otherwise and prove it. Until then thank you for your opinion.
Thanks for the opinion. Facts outweigh opinions at least in the real world. In my world, identical components yield slightly different results in identical radios due to inconsistencies in their factory installed components. The sonar equipment I worked on in the Navy was a different matter. Tighter tolerances result in a higher cost per unit, but simplified alterations since we can use identical componens to achieve virtually identical results. The civilian world is a different ballgame with 20% tolerance components. To make improvements you can't just slap the same component in and expect identical results. Perhaps you could clue us in as to how your opinion was formed.
You're correct the schematic doesn't lie.
You seem to have misinterpreted what I said. Mark's modifications aren't on cheat sheet level as you'd find on CB Tricks forum. If you had two identical Stryker 955's from him you would understand what I'm talking about. R41 and E5 for example will always be different values on identical radios (after modification). To achieve a specific attack and Decay time the values must be adjusted to whatever value necessary to achieve the desired result. All the components that he changed will also be changed on the other radio but the values will always be different between two identical radios. I'm not talking about factory-installed components. I'm talking about components that were added to the radio to change the value of stock components. When you're trying to achieve a specific result you use whichever component gives you the result that you're trying to achieve and whatever component that is it will not give you the same results on an identical radio. That value is only good for that specific radio. It would be completely worthless to write up a cheat sheet for every component replaced on a specific radio because those values will not yield the same results on an identical radio. Radios are not as identical as you think they are. There's a reason your Guru calls them black box radios. It's because he can't make them perform like true HF rigs so he blames the radio manufacturer for his inability to overcome the radios deficiencies. 20% tolerances mean you have to do all sorts of mental gymnastics to achieve identical results even between identical radios. I do agree the original poster should just pick up that Uniden Bearcat radio and keep it stock and don't let any "tweaknicians" tamper with the radio and it will work just fine.
It will look untouched and you will have a difficult time locating any non factory components.So you're saying when I get a radio from him, it'll look like some cobbled together POS with extra crap soldered onto parts from the factory?
You are partially correct. A textbook tech following a service manual won't get you anywhere close. My AT-6666 easily outperforms an Icom 7000 on 11 meters.It's absolutely impossible to make any black box radio perform like a freaking Kenwood, Yaesu or Icom.
You can scream "facts", "logic", and "truth" all you want but that doesn't change anything.It will look untouched and you will have a difficult time locating any non factory components.
It's kinda funny how the folks that disregard the laws of physics make fun of the one guy who configured his bench with those laws in mind. If you'd like to learn something from an authority on the subject you should read this manual. It contains critical information that you and your friends conveniently ignore regarding how to set up a proper RF test bench.
https://birdrf.com/~/media/Bird/Files/PDF/Products/manuals/920-4314C-Manual-042016.ashx
