They do have the potential, imax is notorious for causing rfi & been noisy on rx,
somebody with an imax out in the yard away from the house probably won't have any issues they notice unless they pick a bad coax length,
when you are sat 3 feet from the mast outside your shack pedaling your ACOM 2000 & everything around you is tripping out & buzzing, touch lights like a disco chopped up clippy audio or no audio,
you turn the amp off its working again sort of, but with 100w your kenwoods compressor won't work,
rfi is clamping it down so hard you still have almost no audio so you have to turn compressor off to talk at all,
your swapping jumpers mics & cables, moving stuff around the shack messing with clamp on ferrites banging another ground rod in & banging your head on the desk thinking chokes & radials & good grounding, that's more than most do so wtf is going,
or your brand new ft101d & acom1500 is buzzing its tits off at anything over 400w,
your imax has the radials and a 5 turns on 4.25" choke,
the mast is just outside your shack window grounded through a fat wire to ground rod,
you order 31 & 61 mix torroids to make proper chokes & string some large clampons along the coax,
still no joy cant use the amplifier for rfi,
that's what imax2000 with radial kit, choke, bolted to a metal mast grounded with a short fat wire to copper ground rods can do, w8ji's unlucky mast length.
The fix in both cases was isolate the imax from the mast with a fork handle & force the current to flow in the radials.
