Lost rx green led on my cobra 148 gtl china made , tx lght works, led channel selector works and meter light,
tx works fineCould it be a bad bulb? Is the bulb showing voltage on two of the three legs?
JUST BECAUSE TX WORKS FINE DOES NOT MEAN THE BULB IS NOT BAD.tx works fine
ok i will test the bulb and report backwhat Low boy is getting at is does the RX work on the radio? as he stated the bulb can burn out and RX will still work. read this 2 times and you do not say if the radio RX or not.
i replaced the bulb still a no gook i will test the bulb and report back
Did you test the old LED with a suitable power source? Maybe the LED is okay and your issue goes deeper..i replaced the bulb still a no go
Yup check what feeds the LED, or the LED itself; let us know how you get on Kaos513.
rx side on the bulb reads 064.9 mvYup check what feeds the LED, or the LED itself; let us know how you get on Kaos513.
