That's vertical?
Sent from my iPhone using Tapatalk
It probably has components of both horiz and vert. Maybe one of the engineering types here can chime in and toss some deeper knowledge at this.
That's vertical?
Why are all television transmissions horizontal?
a quote from L.B. CEBIK W4RNL (bold is mine) Antennas
“Man-made noise: This category includes the usual machinery sparking, faulty signs, auto engine sparking, etc. As you can see from thinking about the sources, it largely derives from spark generation and hence produces useless RF over a wide frequency range. Most human-made noise is vertically polarised and of ground wave propagation. Hence, ground-mounted verticals are most susceptible to this category of noise. A horizontal antenna generally shows an immediate 3 dB reduction. Additionally, antenna elevation also helps reduce the noise level”.
Although horizontal antennas are generally quieter than verticals - that isn't always the case. I've gotten plenty of noise when I point my beam at horizontal power wires.
Do you suppose that has anything to do with the fact that they are being emitted from a huge horizontal radiator? Most spark sources of noise are vertical however arcing on a power line from insulators etc. can be coupled into the wires and re-radiated as horizontal polarity even though the original noise source was vertical.
I like having both polarities.
