Need HELP ASAP!! My antenna is down and I can't get it back up until I figure this out. I need to know the correct length for the wire that connects the SO-239 to the Hoop. Also, wouldn't it be better to use #14 Silver Teflon wire since it can take the watt's? This wire is used on amp output transformer's and it take's a lot of heat. Thanks for your help guy's!!
