Dood, can I borrow one for like an hour?I have two of those absurd m2057 tubes in my collection and no, dont even ask me.
The Plate Tune control should peak with the plates between the two extremes. It has no end stop, so if it gets to the end of its range, this will appear to be a peak on the meter.
You can look at the plates to see if they are all the way apart (minimum capacitance) or if they're fully meshed (max capacitance setting).
If the control shows what looks like a peak at either of these extremes of rotation, it's not really a peak. It's the control running out of range before it can reach a resonant peak.
There's a way to tell this from the outside without looking at the plates. If the Plate Tune control has ** two ** peaks in one whole 360 turn, this tells you that it really is reaching a resonant peak.
And if you see just one peak on the meter in one full turn of the knob, it's time to see if the plates are fully apart or fully meshed together.
That will determine how the coil that it's connected to needs to be adjusted.
That control is really just the "fine" Plate Tune control. The coil is the "coarse" adjustment that brings the fine control into range.
22uf is probably way too small. A look at the bias voltage with a 'scope would tell you how much ripple there is on the bias voltage. I would use a 100uf cap for the bias filter.
That's my first guess as to the source of the hum. Again, if you could see the amplifier's output on a 'scope I suspect you would see that sawtooth shape of power-supply ripple modulating the carrier.
Found the folder with the 1979 diagrams in it.
The ECG5221 zener diode is a 105-Volt 10-Watt part.
Here's what the RF schemo looked like before it got marked up.
It's worth noting that the tube's control grid and screen grid are reversed in this diagram. At least they left off the tube socket's pin numbers.
You may or may not need the zener diode.
The exact negative grid voltage needed will change from one tube to the next.
The 1977 Brute has 100ufx450v in that position. The 1978 Brute has 22ufx250v. I will change it My zener is a ECG5161A 150v -5watt. An i do have 1N5408 in it. 238
I reckon i need to take to someone with a scope. 238
When i turn the tune down to about 10 watts the hum goes away, but as i turn it up the hum comes back.
If turning the Plate Tune knob causes the 'hum' to change that points to RF feedback trouble.
