I ran one in the early 90's. I really liked it. Side rejection was good. Turned it with a cheapo TV rotor. I would use another in a heartbeat, great antenna. Another local had (still has) a stacked pair. Haven't heard him for years, I think he passed, but his quads are still up.
Can't beat a quad, no matter it's configuration.
If we had todays durable spreader arms and the like, I believe yagi's would be everyone's second choice antenna. Early quads were constructed with flimsy shit that didn't hold up, but the yagi did.
A quad would always be my first choice.
Oatmeal, here are my Eznec models for a dipole vs the dipole with the elements slanted down at 45* degrees in a V-Quad configuration. I did not tune the the first V-Quad model marked "Not Tuned," and I tuned the last model so you can do a little comparison of a horizontal dipole vs. the V-Quad tuned and not tuned well.
Note: The first dipole was made using only 1 wire. Eznec will not allow any wire to be bent, so I made the 2nd dipole using two 1/4 wave wires, and I fed it in the middle like the 1st model. Notice there is a little difference, but not that would matter at all. In theory it tells us there is a difference, but in real life the difference doesn't matter, just another case of what I seem to claim all the time.
I slant the elements on the 2nd dipole model down to 45* degrees, but I left the dimensions exactly the same, and doing this slanting changes the match at the feed point. Notice this match change in the Source Data report, and there you will see that this slant does make the natural match better, but it is still not perfect, it shows some reactance.
So, I tuned its mismatch out to a near perfect match for the last model noted as "Tuned." This we can see makes for a very good SWR, but this hardly makes a difference in the gain or the angle. Slanting the radials, in this case, does raise the maximum angel a little bit, because the V-Quad is set a bit lower to the ground as a result of slanting.
All the antennas shown here are at 36' feet to the feed point.
I just posted the results in a Recap form for the data the models produced. If you want to see the full models themselves, then let me know.
Hey will eznec model a full wave delta loop, like the maco v quad. My software only does square quads.
No, I'm using yagi cad, it's fairly basic. Anyway back to the maco. Had one years ago Great antenna.good gain and very low swr. It is horizontally polarized ,so locals will be cross polarized and down in strength as stated earlier.What I found was that it worked well even when mounted low .10 ft off the ground it would outperform a 3 element yagi hands down( the top wire of the loop would be 10 ft higher and this I think is what makes the difference) At 50 ft not much between it and a 3 element yagi. V quads tend to be top heavy.If you suffer high winds, you might be better off with a 3 element yagi.
Right, got the manual down. maco are using 11'9 sides on all elements with a top wire of 13'71/2" on the driven.The reflector has a 3 turn coil on the top wire to make the extra( I still don't remember that)
