Marconi,
You were typing with the wrong hand, those fingers got it just backwards. Adding inductance lowers frequency, not raise it.
You're right about a loop typically having an input impedance of about 100 ohms. But, adding more elements to an antenna lowers it's input impedance. The more additional elements the lower that input impedance. A gamma match -raises- impedance, so works fine with an antenna which has a 'too low' input impedance. (Most impedance matching devices found on a multi-element antenna raises it's input impedance.)
See, that's what happens when you hold that beer can in the wrong hand when typing...
You're right 'Doc, I was just checking on you sharper guys.
