RadioTech, that's not a thread hijack
Right now I'm FM only and am only doing it with an HT and the handheld Antenna (which is why it's FM only). Maybe if I get a Yaesu FT-817 someday I'll be able to try SSB mode using the handheld.
I'm not getting a noisy signal, but I was considering the advice of N1ASA in that document I attached to try a preamp if you're using a handheld antenna. I figured that if I could find one cheap enough that delivered 15-50db gain and only 1db or so of noise, then that would be worth a try??
I have a 2m 35 watt brick amp, too. I might try putting 20 watts or so into that Arrow antenna to see what kind of difference that makes also
