Magnum 6000??
That radio is way hot for that amp......the 30 watt model would have been a good match if turned down a bit.
Get it off of it and find a nice single final SSB radio to put in front of it.
I thought about installing a variable power on the ranger but I don't know if I want to do that, after researching it. I have a 148GTL-DX I was could use but I believe or was told it had a 40watt DK
That's not even possible. It probably has a variable dead key from say 2-8 watts and will do 35-40 peak watts.
If that radio has the heat sink on the back it should be a dual 1969 or 2312 final powered radio. The 148 GTL DX+ I owned was dual 1969's good for an honest 30-40 watts PEP.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
