dunno about a "10 meter coil", but,........from the manual.................
"All MFJ-1982 models come with 132 feet of antenna wire and cover 80, 40, 30, 20, 17, 15, 12, and 10 meters. The only difference between the LP, MP, and HP version is the power rating of the matching network. The MFJ-1982 resonates slightly above the 30-meter band, so a tuner is normally needed for transmitting. Also, note that there is small 6-turn inductor wound into the antenna wire about 6-feet from the matching unit. ..."
the dia of the pvc isn't mentioned, but it looks to be about 1 1/2 od +/-
