Marconi working Gain Master vs. Starduster
You were talking about impedance bumps and bad solder jobs. And I said if you were going to be that absolute, you needed to be able to switch faster than 10 minutes.
My point was using two parallel antenna's on different poles is futile and rather pointless because of the underlying problems i discussed. One set up is the way to go.(y)
