Over the years I've used various types and grades of rope for wire antenna supports. The lifetime of whatever I was using varied considerably from months for cheap poly rope found at discount stores (needed in a pinch) to years for cotton and plastic clothes line. As for the past 25 years or so I considered my antenna installations as rather temporary I was satisfied with what ever life I received. Besides the limited lifetime of rope available locally to wherever I was living, the various ropes had varying degrees of stretch.
After having my fan dipole collapse about a year ago due to using cheap poly rope, I started looking for something with a more durable lifetime. Enter Mastrant rope sold by DX Engineering (and possibly other places). The specs on this product are impressive to me so I ordered a 100 meter spool of 5 mm (3/16") diameter rope. It has an 1100 lb strength rating which seemed clearly sufficient for my wire antennas. It is offered in several diameters.
After having it in place for a year the rope used on my fan dipole looks just like it was taken off the spool. It shows no sign of degradation from uV rays and the weather hasn't made it hard and brittle and still plays through the pulleys I use for raising and lowering just fine. The stretch is very low to almost non existent so once tensioned it stays that way. When installing my new 80/160m doublet a few weeks ago I used more of this rope and expect it to remain in place for some time. Our club used it for guys for our temporary crank-up tower during the recent Field Day exercise. It could likely be used for longer stints than just a single weekend.
I highly recommend this product. More info at http://www.mastrant.com
