Marconi what I have tried thus far is running coax through the mast pipe with an rf choke AKA ugly balun at the bottom of the mast. I have no TVI, RFI, CMC issues SWR look as to be expected using the mfj259b analyzer.
Hey wavrider! IMO, it's a good idea to check and compare the possible effects of any modifications to our antenna system.
Based on reports that a coaxial choke, not made correctly, can make matters worse...sounds to me like a good reason to check.
Another install I did not put the rf choke at bottom of mast pipe, same results no RFI , TVI, CMC issues, swr same as one with choke.
A good idea to double check too.
I seem to think, and as is suggested in several articles online,
running the coax through the mast pipe presents an easy method to isolate/shield the coax within the 1st 1/4wl of the antenna effectively decoupling the coax from the antenna where the bottom radials of the starduster type antenna is radiating.
I use to think running the coax thru the supporting mast, like the Starduster does, was done for convenience in the design. Then I saw were Avanti was suggesting a similar installation idea for their Sigma 4, and that made me wonder.
I like my Imax for the multiband coverage but I will never homebrew any more 5/8 wl gp, the 1/4wl does just as well if not better performance IMO.
Some years ago I bought an I-10K. I did it planning to compare it to my Starduster. I found if I just raised my SD'r up and got it within a couple of feet of the 5/8 wave tip...there was little to no difference, and my SD'r was much quieter when conditions were on the quiet side of good.
