meanwhile out in the garage ...
2.00" x 4.34" For approximate scale purposes the vertical black bar (rectangle) is the width of a TO220 package and a bit more .
Next is auto leveling with an archaic CAM program from hell . Hint, remember this ...
MRF101AN/BN first, then on to the MRF300AN/BN
Now , am I going to suffer through the artistic masochism of recreating the bias circuitry on a stand alone board or is someone going step up with a better idea?
I have the code in .nc , .ngc , . gcode , the original art in png, bmp, and svg.
You can ask :)
So, if that first letter in the gadget's name is not the familiar latin letter "u", but really the greek lower-case letter "mu", should you call it the "Mew-bit-ecks".
Cue the nyan cat.
With a mag-mount whip on its back.
Reactions: Rwb
what a great project you are involved with kop!
just got done reading all about it and my hat is off to you sir.
Is this community local to you?
LC
Reactions: Rwb
Cue the nyan cat.
Edgar resembles that remark...
Reactions: Rwb
Ashhar Farhan, the creator of the uBITX himself: “I pronounce it as ‘micro bitx’, you can choose your own.” We all type “uBITX” but it’s not a “U” it is the symbol for “micro”
not to spoil your fun or dis Edgar, but...
Reactions: Rwb
  • @ Geoexplorer69:
  • @ Geoexplorer69:
