MFJ-989D
As long as the power is right and the meter is not losing voltage on keydowns, then leave it be. Check it with a separate volt meter and see if the voltage drops any. Amps will be a bit harder to check without another amp meter. But if it's not dropping voltage on the keydown and is putting out the right power, leave it be. JMO.
Reactions: 2RT307
Says 14.2v firm
I think it's going to be a guessing game but I'd guess the Astron meter. I have an older Pyramid supply that always reads low on the amp meter. It never bothered me since the radio is doing what's it's supposed to.
It's doing what it should as you see above, thought maybe 989D was reading high if power supply was right.
I know this is a fairly old thread but the photos show 14.5V and 26 amps.
That is 377W input power and just a little under 200W out.
53% efficiency. Very possible all meters are close.
73, Paul K4PDM
