Mirage 36hp3
Eldorado828
828 in the Lonestar state (WDX-828)
I Support WorldwideDX.com!
Feb 21, 2016
4,522
8,844
523
The Panhandle of Texas
Just thought I'd throw this question out there. So the new 36hp3's all have a clipped resistor in the j4 location. I'm guessing it was done from the factory but why? Has anyone else stumbled into this yet. I reached out to the palomar guys but they appear to have gone missing from the scene (not sure what ranger plans to do). Hopefully someone else might have more knowledge. By the way the radios work fine after first fixing the typical missed qc issues normally found in the rci built radios.
I noticed the newer (hp3) swings really well from a low dk but only does about 40 pep compared to the 50 pep from the older hp2. There's some capacitor changes in the final section that I'll post some pics of as well and a few other changes.
C252 is now a 220uF electrolytic, c203 is now 391k from 181k, L35 is now a 7 turn from a 4 turn. What I mean by now is on the newer hp3.
I'm trying to do this in different parts so I don't get everything jumbled up haha. In these shots you'll see they've added a pot in the VR5 location as well
that J4 is for the tone control.
one version probably has it, and one doesn't.
haven't looked at the other parts you mentioned but i can tell you that the difference between the 4 turn coil and the 7 turn coil is the difference between a dual final radio and a single final radio as far as i remember.
back when i was doing a lot of DX959 dual final experiments, one of the first things i saw was that you needed to change the 7 turn coil into a 4 turn.
I also recall the coil change with the dual final mods. I don't understand why they would do that here though right?
Both radios have the same functions on the front panel and either of them have a tone control. Some of these changes aren't making sense to me so far
Next up not that it really makes much difference is the echo pcb. It's now a typical RCI mounted to the chassis pcb instead of the before potentiometer mounted pcb.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
