I have experienced similar results with the Wilson 5000. I ran a straight 6 pill with a Galaxy 95T2 driving it and never had a problem.
Currently using the W5000 mag mount with a Rci-69ffb4 and having good results.
You know the coax is only rated for around 400W and that is only if the SWR is almost 1:1? The higher the SWR the lower the power it'll handle before you get arcing between the centre and the braid.
